sblomeke
Mar 04, 2017Follower
Slow WiFi Speed on Nighthawk R8000
Hello, i have Comcast Blast Internet 150MB. My setup is a Netgear N600 Modem/Router with wifi disabled and my Nighthawk R8000 plugged into that. My direct connect wired connection to the N600 gets 18...
- May 15, 2017
It turns out the problem was attributable to Comcast. They symptoms made it appear that it was the router, but Comcast determined it was their exterior lines and they put a filter on the line coming into my building and that took care of it. Now I'm getting 180mbps through the both the Nighthawk router and the Xfinity gateway! Thanks.
JamesGL
Mar 09, 2017NETGEAR Employee Retired
Hi sblomeke,
If you wired a computer to the R8000, what is the speed?
TheWorstPing
Mar 24, 2017Apprentice
i am having this exact issue on my R7900. it seems to be an ongoing problem that has no tbeen addressed by netgear. all they ask is if i have reset router to factory settings/ updated to latest firmware. Yet, neither of these fix the problem. i have the router at stock settings and my speeds on wifi also drop to 30mbs. i have a 100mb connection and when i reset the router the speeds are fine! then a few hours later they drop... has to be some sort of firmware problem since many different netgear routers are experiencing same issue.
NOTE: ( i even replaced the router with another of the same model and still the problem persists.)
