sblomeke
Mar 04, 2017Follower
Slow WiFi Speed on Nighthawk R8000
Hello, i have Comcast Blast Internet 150MB. My setup is a Netgear N600 Modem/Router with wifi disabled and my Nighthawk R8000 plugged into that. My direct connect wired connection to the N600 gets 18...
- May 15, 2017
It turns out the problem was attributable to Comcast. They symptoms made it appear that it was the router, but Comcast determined it was their exterior lines and they put a filter on the line coming into my building and that took care of it. Now I'm getting 180mbps through the both the Nighthawk router and the Xfinity gateway! Thanks.
daharris
Mar 24, 2017Aspirant
I finally found a fix. Installed DD-WRT and download speeds back up to 240 mb/s!! DD-WRT can be found here: https://www.myopenrouter.com/downloads/dd-wrt-r8000
- TheWorstPingMar 26, 2017Apprentice
what is this? and what can i do with it?
