sblomeke
Mar 04, 2017Follower
Slow WiFi Speed on Nighthawk R8000
Hello, i have Comcast Blast Internet 150MB. My setup is a Netgear N600 Modem/Router with wifi disabled and my Nighthawk R8000 plugged into that. My direct connect wired connection to the N600 gets 18...
- May 15, 2017
It turns out the problem was attributable to Comcast. They symptoms made it appear that it was the router, but Comcast determined it was their exterior lines and they put a filter on the line coming into my building and that took care of it. Now I'm getting 180mbps through the both the Nighthawk router and the Xfinity gateway! Thanks.
JamesGL
May 09, 2017NETGEAR Employee Retired
Hi ddeckerx,
Can you post the statistics of the router.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
What is the firmware of the router?
JamesGL
May 14, 2017NETGEAR Employee Retired
Hi ddeckerx,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- ddeckerxMay 15, 2017Aspirant
- JamesGLMay 15, 2017NETGEAR Employee Retired
Hi ddeckerx,
Glad to know it is working now.
