Yellowshock
Dec 29, 2016Aspirant
Slow wired ethernet
Hi folks, I just upgraded from an Asus RT-AC66U to the X6 and have found the ethernet connection to be slow as dirt. My internet connection is 175Mbps down and 25 Up. My Asus consistently clocked 20...
- Dec 30, 2016
Problem solved: return to Amazon.:robotsurprised:
ElaineM
Dec 30, 2016NETGEAR Employee Retired
Welcome to the community, Yellowshock
Have you tried doing a power cycle together with your modem?
Do you have the latest firmware installed on the router?
Do a factory reset after then configure the settings.
Yellowshock
Dec 30, 2016Aspirant
Thanks for the suggestions Elaine. I have tried all of those things, yes. Didn't make a difference. Only once did it briefly hit over 100 Mbps but not after any settings were changed.
Frustrated with this device, about ready to try Tomato on it to see if I can control the hardware more.
