basketballmap21
Jan 25, 2022Aspirant
Specific device not connecting to router while other are connected, works plugged into modem
My new work laptop is not connecting to wifi. It will say 'no internet, secured' or look connected, but not load anything.
All of my other devices are still operating normal.
I tried resetting the router to factory settings but that change anything. Model: R6700v3, all firmware up to date
My work laptop will connect fine to wifi on campus, or work with my cell phone hotspot. Just not my wifi at home.
I plugged into the router directly with ethernet, it still did not work. Plugging directly into the modem did work.
Are you using a work vpn?
What modem/gateway is the router connected to?
- basketballmap21Aspirant
Not using VPN as I can't even get on the internet. It is connected to an Arris SB6190.
have you checked to see if it was blocked in access control?
