bhc65's avatar
bhc65
Spectrum TV
Spectrum Tv app needs to see your router in order to watch the spectrum app in home network. Spectrum tech said they can't see my router so it won't all me to watch local stations through the app. I've resetthe modem & router numerous time to no avail. I'm thinking it the router is either going bad not allowing the app to see that I'm in my home network. If I connect the modem directly into the comouter I can watch Spectrum Tv all channels with no issue. Should I connect the modem to the router I cant watch the local channels on the app. any ideas for solving this issue. thanks ps... the internet works just fine its spectrum tv is the issue
  • FURRYe38's avatar
    R7000P?
    Reset meaning you pressed the reset button on the back of the router for 10 seconds then released and setup the router from scratch?
    • bhc65's avatar
      bhc65
      Arris surfboard sb6183 modem
      Did the reset button on the router.
      Disconnected the power from the router for a minute
      disconnected the power from the modem for a minute
      called Spectrum tech support . Tech rep says he should be able to see my router on his network. He can't see it so I did the following above as suggested. If I log in to spectrum tv on my pc I should be able to see all the channels. I can only see channels as if I was out of the home network. If I connect the modem ethernet cable DIRECTLY to the pc ethernet port I can get all channels like I'm suppose to get when logged into home wifi network
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi bhc65, are you still experiencing the issue?
        Dexter
        NETGEAR Team
