Majid_Aldossary
Dec 09, 2016Follower
Standard wifi remain active
Hi There, I installed my new X8 this morning and been struggling for few hours now trying to deactivate the standard wifi. The first time I started the router it came with 3 standard networks 1...
- Retired_MemberDec 09, 2016
If you're referring to the Genie App and using that App DON't. Login and use WEB GUI.
