Joesmoe517
Feb 24, 2019Aspirant
Still no fix for Chromecast on Nighthawk R6700v3?
I attempted using the fix that apparently used to work (disable SSID broadcast on the 5GHz network, connect to chromecast, re-enable SSID broadcast), but that no longer works. First off, it says to u...
- Feb 24, 2019
I just solved the problem, and wanted to update for anyone having the same issue. Apparently the router decided to block access to random devices, which included our iPad 4 and the chromecast. When i turned off access control, those devices started working.
Cheers!
Joesmoe517
Cheers!
