Asjemeou's avatar
Asjemeou
Strange behaviour R7000
Hi,   Im using a R7000 with firmaware V1.0.9.60_10.2.60 and for a long time it was the heart of my network. Recnetly I recieved a new modem/router of Ziggo and as it also has dual band Wifi and e...
  • Asjemeou's avatar
    Asjemeou
    Jan 23, 2019
    Hi, finaly i made it back and sorry I didnt reply yet, losts of snow out here.
    I followed all your steps and at some point Im confused. I wait your responce and hope I did it right this time?
    • Remove R7000 from your network
      • done
    • Turn it on
      • done
    • Wait for all the lights to settle down
      • done
    • Optional step factory reset R7000
      • done
    • Connect PC to LAN port on R7000 and nothing else (it might help to disable wifi)
      • Done. Connected my pc to LAN port 1 (Default Wifi not disable atm)
    • Go to 192.168.1.1
      • done
    • After  factory reset the setup wizard may kick in here, you'll just have to persevere through those daft questions
      • done
    • When the browser interface comes up
    • Advanced
    • Advanced Setup
    • Router / AP / Bridge mode
      • I am confused here cause selecting Repeater modes gives me a new screen with an option like Wireless repeat function. Do I t start following the other link nowo or do I only click Apply?
    • Follow the prompts and warnings
    • Apply
    • Wait for R7000 to reboot
    • Plug R7000 LAN port into router LAN port
