Asjemeou
Jan 14, 2019Aspirant
Strange behaviour R7000
Hi,
Im using a R7000 with firmaware V1.0.9.60_10.2.60 and for a long time it was the heart of my network. Recnetly I recieved a new modem/router of Ziggo and as it also has dual band Wifi and e...
- Jan 23, 2019
Hi, finaly i made it back and sorry I didnt reply yet, losts of snow out here.
I followed all your steps and at some point Im confused. I wait your responce and hope I did it right this time?
- Remove R7000 from your network
- done
- Turn it on
- done
- Wait for all the lights to settle down
- done
- Optional step factory reset R7000
- done
- Connect PC to LAN port on R7000 and nothing else (it might help to disable wifi)
- Done. Connected my pc to LAN port 1 (Default Wifi not disable atm)
- Go to 192.168.1.1
- done
- After factory reset the setup wizard may kick in here, you'll just have to persevere through those daft questions
- done
- When the browser interface comes up
- Advanced
- Advanced Setup
- Router / AP / Bridge mode
- I am confused here cause selecting Repeater modes gives me a new screen with an option like Wireless repeat function. Do I t start following the other link nowo or do I only click Apply?
- Follow the prompts and warnings
- Apply
- Wait for R7000 to reboot
- Plug R7000 LAN port into router LAN port
Asjemeou
Jan 16, 2019Aspirant
Thanks for you reply.
I want the R7000 to become the repeater and unfortunealty your suggestion does not work cause there is no way to put it in any mode, it just stays in router mode.
michaelkenward
Jan 16, 2019Guru - Experienced User
That means that you are getting something wrong. But given the lack of information you provide on what you are doing, who knows where you err.
I have just been through exactly that process with a spare R7000P I have lying around. It works.
Let's try again.
- Turn it on
- Go to 192.168.1.1
- Advanced
- Advanced Setup
- Apply
Note that doing this will change the IP address of your R7000. If you try to access the R7000 after it is on your network, it may well try to connect to your router.
- AsjemeouJan 16, 2019Aspirant
Hi Michal
I dont under stand why you write : "But given the lack of information you provide on what you are doing, who knows where you err."
I have given all the information as fas as I know. And I also wrote that the R7000 isnt respinding to any button to get it into another modes.
I even cant switch off the Wifi channels (2,4 and 5)....not responding. It's not that I don't have knodgelegde at all but the way the router react atm I cant follow. I also dont know what err I possible can make.
So I'm kinda lost what else I can do. Isn't there the slight possibility that the router is broken?
Due to work abroad I wont be able to read or responce. Late Tuesday or wednesday Im able to continue this road :) (Hope you too)
- michaelkenwardJan 16, 2019Guru - Experienced User
I have read your messages, several times. They do not tell me what you do and what the results are.
Here is what we know from your description:
Atm its in my network and I can login to it but I can't switch it to another mode, like AP or Repeater. I think I tried everything but what ever I try, no result. I followed the manuals available on the Netgear pages. I reset the modem/router to factory default and manualy restarted it many time. Btw, the only way to restart it is by switching the power button off.
Sorry, but that is useless for diagnosing what is happening.
You say:
"I think I tried everything"
What do you mean by everything?
Then there is:
"I reset the modem/router to factory default and manualy restarted it many time."
Fine, what next?
And:
"the only way to restart it is by switching the power button off"
What point are you making there? Do you expect to see some other move you can make?
I described a very detailed process that you should follow.
Go through it a step at a time.
If one step fails for you, report back with which step you were on and what you saw.
It may well be that your device is dead, but my bet is on failure to follow the instructions at some crucial staged.
It may be that my explanation is confusing. That happens. If so, tell us which but puzzles you and we can see if there is a better explanation.
Enjoy abroad.
- AsjemeouJan 23, 2019Aspirant
- done
- Turn it on
- done
- done
- done
- Go to 192.168.1.1
- done
- done
- Advanced
- Advanced Setup
- Apply
