router_help's avatar
router_help
strange Foscam camera issues with R6300 and R6900
TL;DR: foscam cameras work great on other routers outside the wifi network, but do not work reliably with two Netgear routers now. On the latest R6900 router, cameras work well on Cricket (AT&T) network, but do not work well on Verizon LTE network. Same setup with ASUS / Linksys worked great for years, why?
Story:
We have several Foscam cameras that were set up and worked great on my old Linksys WRT54GL (running Tomato) for years.
Then we switched to Cox Gigablast (fiber optic network), and Cox gave us a brand new R6300 AC router in January of 2016.  I set up the static IP addresses of the cameras (outside the DHCP address range), set up port forwarding for each, just like how they worked on my Linksys WRT54GL.
The cameras would come great inside my network, on my Galaxy Note 4, iPhone 6, and other android / iOS devices.  As soon as I switched off wifi, and tried to use Sprint LTE or Verizon LTE, the cameras would be very difficult to access.  They may come up initially for a few seconds, and then the data stream would just disconnect and I woudln't be able to connect to the cameras again.
Thinking that Cox network was the issue, I debugged with Cox and didn't get a resolution.  I then tried putting my old WRT54GL on the Cox gigablast and the cameras instantly came on outside my network, voila!!
So I shelved the Netgear R6300 (running the latest firmware at the time), and switched to an ASUS RT-N66U router, and it worked awesome from January til 2 weeks ago, when the ASUS router lost all wifi connection and refused to connect to wifi clients despite multiple resets.  So I had to come up with a new game plan.
I went to CostCo and purchased the Netgear R6900 (AC1900) router for $159, and set up the static IP addresses of the cameras, and the port forwarding as previously.  I put the Netgear R6900 on the network, and everything worked great inside the wifi network.
Once I turned off wifi, and switched to Cricket 4G or LTE (I switched from Sprint to Cricket), the cameras would come up, a bit slower than the ASUS N router, but they would come up reliably and the data stream would work.   I then tried with my Verizon LTE iPhone 6, and the same problem occurred - the camera stream would come up for a few seconds, then the data stream would die out and I would be unable to connect to the cameras.
So a VERY ODD problem!! The problem is I can't reliably access my Foscam cameras outside my network, very sporadic initial access on my Verizon iPhone 6 on LTE (and this exact set up worked perfecly with the ASUS router before it died), and it works reliably with the Cricket / AT&T network.
I'm thinking the problem has to be with the Netgear routers:
  • Same Foscam camers
  • same Cox giglablast network
  • same client devices (Android / iPhones, all same apps)
  • The ONLY difference is now I'm using a Netgear router, as opposed to the Linksys WRT54GL or the ASUS Rt-N66u
FWIW I'm using the latest firmware with the Netgear R6900 - V1.0.0.4_1.0.10.
I'm kind of at a dead end trying to figure out what the issue is with Netgear.
Any thoughts from the advanced tech heads here?
  • TheEther's avatar
    TheEther
    Jun 11, 2016
    Turning off Port Scan and DoS Protection is not a big deal.  It just disables some extra heuristics that drop traffic more aggressively.  The main protection comes from NAT and that, by necessity, remains enabled, so your network should still be safe.
    • router_help's avatar
      router_help
      This looks to be the answer below. How can Netgear let this bug be unanswered for so long??  I'm shocked at the poor quality of Netgear firmware.
      The foscam cameras disconnecting when not on home network is because of a known issue with Netgear's firmware. It is because it is thinking the cameras being accessed from the outside network is a DoS attack. If you go into the router settings and go to Advanced, Wan Setup, and then CHECKMARKDisable Port Scan and DoS Protection. This will disable the DoS protection and fix your issue. It is enabled by default. Sadly this is the only way to resolve this. I have the R8500 and Netgear just released 1.0.2.64 firmware for it that fixes this issue so you don't have to disable the protection for it to work properly. in the R8500s new firmware release notes it states:
      • Fixed the DDos false detect issue when accessing multiple IP CAMs from Internet.
      They also fixed the annoying Origin download bug in this release too supposedly (not related to the Foscam issue):
      • Fixed a potential router reboot issue when dynamic QoS is turn on.
      It does not look the R6300 or R6900 have a new firmware with the fix yet. So your only solution will be to Disable Port Scan and DoS Protection
      • TheEther's avatar
        TheEther
        Guru
