guatelize
Nov 05, 2015Aspirant
Stream Smart TV audio to LAN speakers
I have a Samsung Smart TV ue48h6200 & Sony Airplay/Lan/audio Jack Speakers Sony RDP-X700IP (1x) & SA-N310 (2x) and wish to improve audio from my TV to these speakers. Is it possible to connect them a...
- Nov 05, 2015
You should do your own research to confirm the following. It looks like Samsung Smart TV's can send sound over Wi-Fi, but only to Samsung Multiroom compatible speakers. I think you are out of luck with your streaming to Sony speakers. Source: Samsung Smart TV manual.
Why don't you connect the audio out of the TV to the audio in of the speakers using an audio cable?
TheEther
Nov 05, 2015Guru
- guatelizeNov 10, 2015Aspirant
Thanks for your reply, I will try your suggestion, but I wanted to avoid the quantity of wires.
Regards
Olivier
- netwrksNov 10, 2015Master
There are also bluetooth adapters that can trun wired speaker into bluetooth speakers. If you goolge bluetooth speaker adapters you should be able to find some..
