guatelize
Nov 05, 2015Aspirant
Stream Smart TV audio to LAN speakers
I have a Samsung Smart TV ue48h6200 & Sony Airplay/Lan/audio Jack Speakers Sony RDP-X700IP (1x) & SA-N310 (2x) and wish to improve audio from my TV to these speakers. Is it possible to connect them a...
- Nov 05, 2015
You should do your own research to confirm the following. It looks like Samsung Smart TV's can send sound over Wi-Fi, but only to Samsung Multiroom compatible speakers. I think you are out of luck with your streaming to Sony speakers. Source: Samsung Smart TV manual.
Why don't you connect the audio out of the TV to the audio in of the speakers using an audio cable?
guatelize
Nov 10, 2015Aspirant
Thanks for your reply, I will try your suggestion, but I wanted to avoid the quantity of wires.
Regards
Olivier
netwrks
Nov 10, 2015Master
There are also bluetooth adapters that can trun wired speaker into bluetooth speakers. If you goolge bluetooth speaker adapters you should be able to find some..
