ceristeed
Jul 07, 2025Follower
Stuck on Router Password Reset
I've tried login in to my R8000p router today and used the wrong password, then the right password with caps on by mistake. Not my finest hour..... 192.168.1.1 is now redirecting me to the Router...
CrimpOn
Jul 07, 2025Guru - Experienced User
My impression is that Password Recovery is triggered when someone enters an invalid password three times in a row.
It might be that closing the web browser, waiting a while and then starting the login process again will work.
Jul 08, 2025Guru - Experienced User
CrimpOn wrote:My impression is that Password Recovery is triggered when someone enters an invalid password three times in a row.
If not, you might have to do a paper-clip reset.
