Guac
Mar 12, 2024Aspirant
sudden 403 on a single website R7000
10 yr old Nighthawk R700; has worked like a champ.
Suddenly delivers 403 firbidden trying to access ONE website (a broker) (Tradestation.com) for ALL devices in house.
Usual tricks don't work (reboot PC, power cycle modem, router)
What DOES work is bypassing Nighthawk by plugging modem straight to PC.
Any thoughts/fixes come to mind for this bizzare behavior?
Thank you
Thanks all for the suggestions. For the sake of closure:
I Replaced my 10-yr old workhorse R7000 w/a new AX4200 (RAX43) which resulted in a new IP being assigned. Problem solved.
Is any Armor or parental controls enabled on the router?
Any changes made to the router as of late?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Try different DNS on the router from the auto detected ISP DNS by the router?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.- GuacAspirant
No
No
Version1.0.9.88_10.2.88
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Motorola MB8610
Huh? I have "Get Automatically from ISP" checked when I log into the router. I have not tried "Use these DNS servers" option (out of fear of the unknown)
yes
Turn on the router and wait 2 minutes for it to connect.Turn on computers and rest of network.
Done many times; problem still there
It probably won't cause the single-site blockage, but that firmware is seriously out of date, near on four years old. About 10 versions behind the latest.
R7000 Firmware Version 1.0.11.216 - NETGEAR Support
I have seen odd blocked sites. They usually boil down to something at their end or to my browser.
