dougjp's avatar
dougjp
Tutor
May 21, 2020
Suggestions for Upgrading a N750 N Dual Band To ?
The N750 still works, however looking to upgrade to something 'better'. Reasons are; (a) the 750 is over 7 years old, (b) looking to increase my internet speed package and thinking that will expose weaknesses I don't have now, (c) security, and (d) hoping for better powerline speed and wifi distance (the latter isn't a major thing, the house isn't that big and I can get some signal everywhere).
There are so many models, either I throw up my hands and use a dart board to pick one, or try for ideas here!
I don't know if a Nighthawk or a normal router is appropriate. I don't have a smartphone and all wireless devices are using 2.4. I can't imagine ever needing the new AX but maybe AC will help? Two computers and a powerline are ethernet wired to the router. A Laptop doesn't even have a 5G hookup option. Video streaming is the main volume use.
I'm thinking of spending around $ 200- but that is flexible. Like most everyone, i don't want to spent way more for something that doesn't do more for my situation.
I really am lost with all the options out there, and would appreciate some help :).
  • dougjp's avatar
    dougjp
    May 22, 2020
    Thanks, yes I needed directions around this place, and they are helpful. :smileyvery-happy:
  • michaelkenward's avatar
    michaelkenward
    A good place to start is with the product pages. Fill in your needs and circumstances, and see what comes up.
    Routers here:
    Wifi Router | Wireless Routers for Home | NETGEAR
    Fancier stuff with a focus on wifi here:
    Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
    See what takes your fancy, and what fits in with your budget. Then check this place for users views. (But remember this place is where people bring problems, not praise.) And see if you can find a review site that covers what you are thinking of buying.
    • dougjp's avatar
      dougjp
      Tutor
        michaelkenward
        Whatever you do, don't get sucked into anything too complicated.
        What with your powerline setup, and the intended us, you don't need lots of bells and whistles, especially the newest wifi stuff which seems to be causing great grief as the standard settle down. You are right to beware AX.
        I'd say stick to your budget. For $200 you can get something of a workhorse nature.
        I am happy with my ageing R7800, one of the least troublesome routers discussed around here.
        By the way, you may not need anything better to work with a faster Internet service. The WNDR4000 is up to most things, unless you are going to Gb.
