frankbuck
Jun 28, 2017Aspirant
Support in China
Hi, I live in Shanghai, China and recently bought a R7000 here in China. After unwrapping and connecting it asked for a firmware update, which I started. After that I never get in contact with i...
- Jul 07, 2017
Hi frankbuck,
Click on the link below to contact support.
https://www.netgear.com/support/contact.aspx
-Select "Get help on my NETGEAR product"
-Select your country
-Enter the serial number of your router
-Then select "I cannot find an answer to my problem, I would like to contact NETGEAR support."
-Select Open an email ticket
frankbuck
Jul 05, 2017Aspirant
So no people from Netgear in here? I would really like a solution to this, and how to get in contact with Netgear....
- William10aJul 05, 2017Master
If the router is bricked you may be able to use a serial cable attached the main circuit board to reflash it will leave a link if you want.
- frankbuckJul 05, 2017Aspirant
William10a wrote:If the router is bricked you may be able to use a serial cable attached the main circuit board to reflash it will leave a link if you want.
Hi William,
Thank you, you already posted that I think, much appreciated. But I am looking for Netgear to take some responsibilty in their product, that didn't manage to do a firmware update.
I can not do those modifications to the router myself...and I think it's more a matter of someone knowing the right path to Netgear and their support people here in China.
Right now I'm stuck with a useless product, and I would really like to see it work again!
Again, thanks for your reply!
Have you checked to see what rights as consumer in China you may have under their warrnety laws to help, I also feel if you sale it you should make it right if it breaks.
