symone_84s
Oct 01, 2016Aspirant
Switch / router install
i have to install my home network, I need to know what is the socket of my switch GS324 to use to connect the switch to the router. There is a link port, or all go well?
after connection I have to set something in the router?
Any port will work.
Any port will work.
- microchip8Master
A switch accepts any port. Also your model is unmanaged which means you don't have to change or set in the router anything. Just connect them with a cable and you're good to go
- symone_84sAspirantMany thanks!!
