bimox
Jun 01, 2022Follower
Telnet on R8000
Hi, I searched all the forum for a definitve answer, but i found very few regarding R8000.
I have 1.0.4.84 and I'm trying to enble telnet in order to configure WOL from internet.
- debug page doesn't have item
- Telnetenable doesn't work
- nte doesn't work
Is there anybody who succeded enabling telnet on a R8000?
Reading THIS i will try to set default password as soon as possible: it seems that the user found the solution for his R7000.
Thanks
I believe for security reasons, NG has removed telnet from all of it's products.
That happened with firmware updates.
If this is for a temporary issue, reverting to older firmware might work.
Then visit here:
http://routerlogin.com/debug.htm
You may have an option there to enable telnet.
It is not a good idea to leave the router on older firmware without the security updates that came with newer releases.
