Free_Rick
Jan 03, 2026Aspirant
The radio of 5Ghz and 2.4 Ghz don't turn on
Hi Everyone, I have somewhat exactly the same issue. The radio of 5Ghz and 2.4 Ghz don't turn on. I already tried the 30/30/30 reset (I think all 3 methods) Changing the firmware to the ...
Jan 03, 2026Guru - Experienced User
If the radios are NOT recovering after a 30-30-30 reset or recovering the FW using the telnet process, the radios are probably gone bad and you'll need to replace the router or disable ALL wifi radios on the router and install something newer in AP mode to provide new WiFi signals.
Good Luck
