Rosensama
Jan 19, 2016Aspirant
Transmit power and antenna gain for Nighthawk x6 and x8 models?
Hi All, I checked the tech specs on the product pages for the Nighthawk x6 and x8 models and didn't see any mention of this. What is the transmit power for 2.4 GHz and 5GHz for each? Also what...
- Jan 25, 2016Someone was nice enough to PM me this useful info.
R8500 Transmit Power
R8500 - Antenna Gain
R8000- Transmit Power
R8000 - Antenna Gain
Retired_Member
Jan 20, 2016Does the antennae gain or loss figure into the output level so the device does not exceed it's ERP?
LeeH
Jan 20, 2016Prodigy
The power remains the same with different antennas. The radiation pattern changes to a squashed doughnut pattern with high gain antennas. You loose omni direction and gain range with higher gain antennas.
http://www.techrepublic.com/blog/data-center/80211-time-to-clear-up-some-antenna-misconceptions/
http://en.data-alliance.net/range-radiation-patterns-antennas/
