lrsmith1957's avatar
lrsmith1957
Trouble shooting - Nighthawk R7690P Firmware v1.4.4.94 not broadcasting 5G signals
My Nighthawk R7690P has been working fine for years now but I've recently noticed the 5G options have disappeared from the options in the network options on all my devices. That includes my laptop, my Android phone, my wifes Iphone and Ipad. To my knowledge there has been no change to my cable service so I have no idea how they can just not be there.
My 2.4ghz band works fine.
I've rebooted all devices, including unplugging and powering up in the sequence recommended in the user manual. One time after powering up the modem and router the 5G signals appeared briefly on my phone but then disappeared.
Anybody have any idea what could be happening with this router?
Thanks for any replies.
  • Have you logged into to check if smart connect is enabled?
    Smart connect combines the 2.4ghz/5ghz channels into one ssid so they don't show up as separate.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
    A USB Laptop cooler is recommended under the router. Keeps the router cooler and helps avoid heat damage over time.
  • plemans's avatar
