hankthehillest's avatar
Jul 14, 2024
Trying to Use R7000 with United giga Blast router/modem
ok, to preface, i am not internet tech savy. i dont know terms or anything, so please explain like you are talking to a child lol. so i recently moved into a new house that came with a nighthawk r7000 router installed. i had to aquire my own internet service and so i had a guy come out and install united fiber, they installed their own equiptment, and the tech said that the nighthawk was a far better unit than theirs. however, i dont know how to make it compatible. i factory reset it already, but it says connected without internet when i plug it into the service box. (it was hooked up to this same box when i moved in, so it used the same provider previous to me moving in). how do i make it work?
  • michaelkenward's avatar
    michaelkenward
    What equipment did they provide? A modem? Modem router? Gateway? Make and model?
    How fast is the new Internet service? What is it DSL, cable or optical to you?
    The R7000 was OK in 2017, when it came out. If the ISP supplied something newer, the tech may not be quite right.
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem/ONT and router been performed?
    Turn off and unplug modem.
    Turn on computers and rest of network.
