Retired_Member
Aug 08, 2017Tunnelblick VPN Client on a Mac does not change the public IP
confI have followed the help link https://kb.netgear.com/25389/Enabling-VPN-service-on-a-Nighthawk-router-using-a-MAC-OS-computer However, my public IP is still the same. I did some researches ...
- Retired_MemberNov 13, 2017
Netgear support contacted me and mentioned the VPN is acutaully to be used outside of your home network. It's not about to hide your IP to some privacy concerns.
mskeels4270
Aug 23, 2017Tutor
I have the same issue here. What needs to be added to the conf file to make this work for Mac OS?
Retired_Member
Aug 23, 2017After I talked with the customer support, I learned that the VPN is different than the VPN we were trying to do. This VPN is to allow users outside the home network to use the home network.
- mskeels4270Aug 23, 2017TutorThat doesn't sound right. It should also allow you to browse the web as if you were on your home network as well. That's why you have the option to "home network only" or "home network and internet" as options.
- Retired_MemberAug 23, 2017
That's what I got from the customer support. I wish you can find out why and let me know too.
- bardaravineSep 30, 2017Aspirant
Did this ever get fixed or addressed? I have the same issue. Would like to browser internet like I'm home. It's why I purchased this router.
