BlnBiker's avatar
Apr 08, 2023
two R7450 have different speeds
I have 2 identical R7450 wifi radios that if a device connects to one or the other it gets different speeds
On one the speed is only about 1/3 than on the other radio
any idea anyone what might be the reason ?
  • michaelkenward's avatar
    michaelkenward
    What firmware version do you have on the devices?
    A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
    It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
    Are you testing with the same Wifi clients on the same network and with the same test site?
    • BlnBiker's avatar
      BlnBiker
      Tutor
      fimware on both is V1.2.0.92 _1.0.1
      The modem is a Spectrum EU2251
      the router is a TP-Link ER 605 V2
      both nighthawks are set to "AP" mode (router disabled)
      speed test are done with the same device on the same network with the same test site (Ookla)
      • plemans's avatar
        are you disabling smart connect so you can specify what band to connect to?
        To many times I've seen smart connect on and people connecting to the 2.4ghz when its a slower network.
        Also, what channels are you using because you're running 3x routers. The 2x R7450's and the one other.
        Could be you're causing interference on one of them thats slowing things down too.
