ChibiKev
Jun 11, 2018Tutor
Unable to access attached devices and access control
So there's a problem that occured upon entering the router's setting, http://routerlogin.net, the problem is that I'm unable to access the Attached device and access control settings. It just appears...
- Jul 06, 2018
Yes, the issues has been fixed. The instructions will be said below:
The first thing to do was to update the firmware to a new version that I don't think have been released yet.
The download link for that is http://files.netgear-support.
com/go/?a=d&i=vhvuk2W5Kr
Edit: It seems like that link no longer works, so I have re-uploaded it to Mediafire. The download link will be listed below:
http://www.mediafire.com/file/o1vbkwo4ogf3qlq/R9000-V1.0.4.3RC2_new.img
Download that and install it to your router, using a computer.After it's successfully installed, go to your router and on the back off it reset it. It should be factory reset so that when you log onto your router, it would be just like new.
This was basically the steps I took in solving it.
Also, for more information, refer to the post on here:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/quot-Attached-devices-quot-and-quot-Access-Control-quot-not/m-p/1599981#M98097
I spread the news about the issue and how to solve them on there too. Hopefully, some other people who also have it solved will be of help.
Blanca_O
Jun 11, 2018NETGEAR Employee Retired
Hi ChibiKev,
Welcome to NETGEAR Community!
I have sent you a message. Please check your inbox.
Blanca
Community Team
