SithLord2K's avatar
SithLord2K
Unable to Access Nighthawk R7000 Web Interface over wired connection
I have the Nighthawk R7000 router, it is in router mode. I was originally able to access the web interface without issue. But for some reason I can no longer access it via wired connections. I can access it from my wireless connections. I cannot see any reason why this would be. I tried Edge, Firefox and Chrome browsers. Any help would be appreciated.
  • > Unable to Access Nighthawk R7000 Web Interface [...]
       Firmware version?  Connected to what?
       "Unable" is not a useful problem description.  It does not say what
    you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
    > [...] I cannot see any reason why this would be. [...]
       Nor can I, but I also can't see which URL you're using, or which
    error message you get when it fails.  I might guess that your wired and
    wireless devices do DNS differently, but with no useful information,
    that's a shot in the dark.
       General advice: A forum or Web search for an actual error message can
    be much more helpful than a search for "unable" or "can no longer".
    • SithLord2K's avatar
      SithLord2K
      When I try to navigate to the IP address of the router 192.168.1.1 I get a message that internet access is blocked. I have set up no blocking on the router. The firmware is version 1.0.11.126.
      When I navigate to the same IP address on my Pixel 5 phone I can access it, but due to the size of the screen navigation is cumbersome.
      I have reset the router to factory settings twice and set everything back up. But I had to do so from my phone.
      This only seems to happen when I try to access it from a Desktop PC. Which as mentioned is hard wired.
      I have searched this forum and the web without success which is why I am posting here to see if there is anything else to try.
      I have checked to make sure the site is not blocked and cookies are enabled.
      • antinode's avatar
        antinode
        Guru
        > [...] The firmware is version 1.0.11.126.
           Ok.  That still leaves:
        > [...] Connected to what?
           How did you determine that that's "the [LAN] IP address of the
        router"?
        > [...] I get a message that internet access is blocked.
           Which part of "actual" did you find confusing?  Copy+paste of the
        actual message might be more helpful than your summary of the actual
        message.  Revealing which browser you're using might help in
        interpreting the message, too.  Firefox would be most convenient for me.
        (Assuming that that message is coming from the browser.)
           "try to navigate" from what?  What's the IP address of that device?
           I got that.  But, by itself, that shouldn't matter.  "hard wired"
        directly to a LAN Ethernet port on the R7000, or what?  How many
        different "hard wired" devices behave the same way?
           Normally, "192.168.1.1" would be entirely local, and accessing it
        would not involve Internet access, only LAN access.
