Henderson
Jun 14, 2016Aspirant
Unable to access R7000 GUI setup pages or internet
I have Comcast hooked up to a single PC right now using a Motorola MB7420 modem and that works fine. When I hook up the R7000 router though, I can't access the setup pages, nothing I've done help. ...
- Jun 14, 2016
Try this. Since you reset the router few times it is in factory default state. Don't connect modem, just LAN cable from your PC to router.
Run a command 'ping 192.169.1.1' Did the command run successful? Also try remaining 3 LAN ports. Ir ping command runs OK, then try to access router after clearning browser cache and/or try different browser.
VE6CGX
Jun 14, 2016Master
- HendersonJun 14, 2016Aspirant
That did it! Thank you so much! While I had the PC directly connected to the router, I left pretty much everything default for now except for passwords and wifi logins. I did not bother renaming the 3 LAN ports since it looked hopeful this was going to work. Then plugged the modem back into the mix and powered it off/on and I now have internet through the modem.
I had forgotten to mention in the first post that I had tried Firefox originally, then also Chrome and IE just in case a cache was messing things up, and all 3 browsers had the same exact response. And I also tried a different port in case one was bad.
Thank you again, I'm a happy camper now!
