durnurd
Oct 23, 2016Aspirant
Unable to connect to R7000 AC network
I just purchased an RNX-AC1300PCE Wireless Dual Band PCI-Express Adapter. After installing it, however, I can only connect to my R7000's 5GHz network in 802.11a or the 2.4GHz network in 802.11. I hav...
- Oct 24, 2016
Looks like there's new drivers for the card, if this is yours... Rosewill link
EDIT: Ensure WMM is still enabled on the router.
Retired_Member
Oct 24, 2016until you figure it out try broadcasting the SSID and be sure it's unique
WMM in card setup does it have a enable option,
- netwrksOct 24, 2016Master
- Retired_MemberOct 24, 2016
I thought of that also but his speed of 50+ seemed to rule out (WMM) it being disabled
DOH.. I missed that part.....
- durnurdOct 24, 2016Aspirant
Interesting...
The drivers are indeed up to date. The link is the same one I originally downloaded, and while it says that it was updated in September, the date on the driver itself is still 2014 (weird, right?)
WMM was not enabled on the router. I turned it on there, and also changed it to Enabled on the card settings, and now it's reporting around 150-250 Mbps based on interference, and is on 802.11n, which I suppose is better, but I'm still apparently not getting the AC connection I want.
Now I'm wondering what other settings may be incorrect on my router. I have done a bit of customization on it from time to time, such as assigning static IP addresses and some port forwarding. I don't recall turning WMM off, though. I don't know why I would.
- Retired_MemberOct 25, 2016
At two bars of signal the Rate will drop significantly. The router ALWAYS broadcast in AC it cannot be disabled focus on the client and it's settings
