durnurd
Oct 23, 2016Aspirant
Unable to connect to R7000 AC network
I just purchased an RNX-AC1300PCE Wireless Dual Band PCI-Express Adapter. After installing it, however, I can only connect to my R7000's 5GHz network in 802.11a or the 2.4GHz network in 802.11. I hav...
- Oct 24, 2016
Looks like there's new drivers for the card, if this is yours... Rosewill link
EDIT: Ensure WMM is still enabled on the router.
Retired_Member
Oct 25, 2016At two bars of signal the Rate will drop significantly. The router ALWAYS broadcast in AC it cannot be disabled focus on the client and it's settings
netwrks
Oct 25, 2016Master
I have an Intel chipset radio in one of my laptops. It has a setting - VHT - which allowed me to connect at 867 Mbps. Hopefully, your wireless card has a setting similar to VHT. You may have to go through every setting for your card. Change a setting, do some testing. And, or, try a different card.
- Retired_MemberOct 25, 2016
866 all day long @ 30' & 520 @ 50' Using Intel AC 7260
- netwrksOct 25, 2016Master
@searay wrote:@866 all day long @ 30' & 520 @ 50' Using Intel AC 7260
Yup, that's the one I have also. Works like a charm!
- durnurdOct 25, 2016Aspirant
I brought my router up next to my computer just to see what that does for it, and I'm getting 866 now as well. But it's still listed as an 802.11n connection. I guess it's just lying? I'll just need to get a few better antennas I guess.
