sedsgrhg
Jul 26, 2021Aspirant
Unable to connect to Wifi, LAN works fine
I used Nighthawk R6000 router until suddenly none of my WiFi devices could connect anymore. "Unable to connect to Network". I tried several solutions including downgrading the firmware, but nothing worked.
I then got the R8000 an here the same thing. Windows 10 Laptop, Macbook, Android + IOS device, Samsung TV, nothing will connect via WiFi. But all works fine with cable.
Also I have tried several solutions like disabling 20/40 auto, downgrading the firmware to various versions as described in the forum but nothing works. This is so frustrating, especially since I had to pay extra to change the R6000 to the R8000.
Please provide a workaround or a solution. Otherwise I have to switch to another brand, which I really dont want to.
Do you have the R8000 or r8000P? You have one in the paragraph and the other in the signature.
what firmware is on it?
What modem/gateway is it connected to?
Does it not connect to the wifi at all? Does it connect and say "connected, no internet" what is actually happening?
- sedsgrhgAspirant
It's the R8000, no idea why the Signature says R8000P, I registered the serial number, but the box clearly says Nighthawk X6 AC3200 R8000.
Currently it runs on Firmware V1.0.3.54_1.1.37, after having tried 1.0.4.28 as suggested in another solution in the forum. Obviously also the latest Firmware does not work.
Modem is just your default ISP (local provider) Broadband Modem with integrated WiFi router. I dont have any issues with Internet, all configured fine and when I connect any device via LAN all works fine.
I managed to get one device to connect with no internet, but only after I have assigned a static IP to the NIC with a 16 bit netmask prefix instead of the 24 bit that the router IP address is and DHCP should provide. If I set the NIC to DHCP I always get "Unable to connect to the Network".
What actual modem is it? if it has integrated wifi its a modem/router combo device.
running multiple routers can cause issues. Its called a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
have you tried the R8000 in access point mode?
I'd upgrade the firmware to at least the 1.0.4.28 firmware. Its the version prior to netgear armor. the Latest is 1.0.4.68.
If you upgrade, do a factory reset and then during the install, put it in access point mode.
