Oscar400's avatar
Oscar400
Follower
Nov 01, 2019
Unable to enable QoS to my router
So I just did a factory reset on my router and when I went to change the settings on my router (enable QoS)and it doesn’t work It tells me ”The speed test fails to detect the bandwidth , please check your internet or try again later” but I know that my internet is fine because I run a LAN cable to my pc and I’m on the internet just fine Then I tried agin the next day and it still doesn’t work can someone help me
  • There is nothing you can do. This is a bug in the firmware. It's been patched in some models, like the R7800, but in others it isn't. You'll have to define your upload/download speeds manually to get QoS working
1 Reply
