Hawkeye1027's avatar
Hawkeye1027
Unable to port forward on genie/R7000
I need to port forward for my security cameras, but the Port Forwarding option in NETGEAR genie is grayed-out and unavailable.  Is this because the router was marked as an access point in the initial...
  • TheEther's avatar
    Nov 29, 2016
    Port forwarding is unavailable when the router is functioning as an Access Point.  Is your modem a pure modem or is a combination router and modem?  If it's the latter, then you need to set up port forwarding on it.
