Zapatta
Sep 04, 2016Aspirant
Unable to reach Router using IP from one PC however can reach from another PC.
I have gone through all other posts related to this topic and believe me this is a unique situation. I am failry good at troubleshooting these things in the past and when i am unable to do myslef i ...
- Sep 05, 2016
I had my suspisions with Kaspersky and thought that disabling the protection or the Firewall should eliminate that aspect.
But after looking at Kaspersky forums regarding this topic it seems like this is a fairly common problem which Karspersky.
And amazingly the solution is to uninstall Kaspeersky then connect to the router and reinstall Kaspersky.
As this kinda thing involves rebooting the PC atleast 2 times i am going to do this over the next weekend.
Reminds me one of Spocks memorable quotes.
"Once you have eliminated the impossible, whatever remains however improbable, must be the truth".
Will update after the moment of truth next weekend.
Thanks you guys, you are all awesome.
IrvSp
Sep 04, 2016Master
Try a different BROWSER. Maybe the CACHE needs to be cleaned out of the one you are using?
Try a PING to the ROUTER too. See what happens.
Check you network settings. Maybe it is trying to use a different DNS?
