ukwildcat4life
Jan 27, 2017Star
Unable to register router for genie remote access
Hi everyone......I am having a very difficult time trying to successfully configure my R9000 to use the genie remote access app. A week or so ago I purchased the Orbi system and had the same problem...
- Jan 30, 2017
Neverymind........I retured the R9000 for a refund after tech support promised to call me back two days in a row and troubleshoot and never did.....I'm done with netgear........
ElaineM
Jan 27, 2017NETGEAR Employee Retired
Welcome to the community, ukwildcat4life
Can you post a screenshot of the exact window you're getting?
- ukwildcat4lifeJan 29, 2017Star
HI elanie; thanks for replying ..... I am going to attach a screen shot of the error message I get when trying to register my R9000 for genie remote access......here is something odd to think about.............if I take my AT&T Uverse gateway out of bridge mode to where there is a double NAT going on the genie remote access will work but as soon as I bridge the gateway it will not register or work...another odd thing I have noticed is that in the past week I have brought three different Netgear routers to my home and each time my gateway is put into passthrough mode my WAN IP address is the same every time.....................even if I reboot my gateway it still passes the same WAN IP address to the netgear so I'm not sure if that would have anything to do with this problem............when I take the gateway out of bride mode then the netgear router has a different WAN IP it begins with 192....... which we know is double NAT but I definitely don't want to leave my network set up to doube NAT just go use the genie remote access app........I just can't figure out how the Orbi worked flawlessly with gateway into bridge mode yet the R7800 and now the R9000 will not?.............I hope this info and screen shot will help............thanks, James
- ukwildcat4lifeJan 30, 2017Star
- ElaineMJan 30, 2017NETGEAR Employee Retired
I apologize for any inconvenience this may have caused you and for not resolving it sooner.
Have a great day!
