tlinn's avatar
tlinn
Unable to upload images from my Canon EOS R5 to the internet through my Nighthawk R7000 (Err 127)
I use a Nighthawk R7000 / AC1900 router. I recently purchased a Canon EOS R5 camera. One of its features is the ability to wirelessly upload photos to Canon's image.canon website. If I tether my camera to my iPhone's wifi hotspot, this feature works fine. However, it does not work at all when connecting through the R7000 router.
My camera does show up as a connected device. I am able to transfer wirelessly through the R7000 from my camera to my local workstation. No problems whatsoever. My camera is also able to send an email to me via the internet through my R7000 wifi network. This suggests to me that the hardware is all working fine. It also makes me think that there is some kind of security feature or other configuration setting on the R7000 that is preventing either the transfer of images to image.canon or a connection to image.canon. This is where my limited ability with routers, networks, and WANs ends.
Does anyone have an idea of what setting might need to be tweaked to get the R7000 to allow my camera to upload to the internet?
  • michaelkenward's avatar
    michaelkenward
    I find that Canon's wifi feature isn't the easiest to set up.
    Can you connect the camera to the SSID on the R7000?
    Is it just to Canon's website? I haven't used that in some time.
    Seems to work just fine here. But I have an Orbi router in the middle.
    Maybe I'll see what the R7800 and R7000P can do.
    What firmware do you have on the R7000?
    • tlinn's avatar
      tlinn
      Thanks for taking the time to respond, Michael. Your questions are answered in line below.
      Yes. I can successfully connect to both the 2.4GHz and 5GHz networks on my R7000.
      Yes, though image.canon is the only internet site I have tried to connect to. I am able to wirelessly connect to my HP workstation on my local network using EOS Utility. On the R5, this is a different setting in the Wi-Fi/Bluetooth connection menu ("Upload to Web service" vs "Remote Control (EOS Utility)").
      Interestingly, I am able to connect my R5 to image.canon using my iPhone X's wifi hotspot. I had originally assumed this was because I was bypassing the R7000, but after further consideration I realize that my iPhone has been connected to my wifi network while tethering so the R5 was still accessing the internet through the R7000 using the iPhone X as an intermediary.
      V1.0.9.88_10.2.88
      • tlinn's avatar
        tlinn
        I don't know if this is a solution so much as it is a workaround. I discovered that connecting to my R7000's guest network instead of using my normal login, the R5 connects immediately and works as expected. I don't know why this makes a difference. If anyone has an explanation I would be interested. When it comes to router configuration, I am pretty ignorant.
