Rbooe05
Jul 13, 2017Aspirant
Updated firmware now server dns address could not be found
I updated the firmware on my nighthawk router and I use the dynamic DNS program as well as port forwarding for my cameras. After the update I get a random error when connecting to any websites. It reads server dns address could not be found.... I get this on all my devices and sometimes will automatically load after a couple seconds. Any ideas? Thanks!
I actually ended up resetting the router by holding the reset for 10 seconds. Then i set up my networks and my port forwarding again and i went the backup screen and saved my settings to my laptop. Then i upgraded the firmware with the same results. I then went to the backup screen again and i restored all my settings i had saved on my laptop and it rebooted and worked. Not sure whats going on with that but it worked for me! Hope that helps
- Rbooe05AspirantAlso I'm using att uverse if that matters
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So a factory reset is the first thing to try if you have problems with new firmware.Backup the device's settings first, just in case it doesn't work and you want to recover the settings. If it does work, retrieving the settings may break it again.
- Rbooe05AspirantI did reset it to factory and I didn't save any changes. Just manually entered my port forwarding information and everythinf
- GearNetRouterVirtuosoDid you find a solution? I have an R7000 router, upgraded firmware and installed OpenVPN for Android and have the exact same problem!
- Rbooe05Aspirant
