eltoms's avatar
eltoms
Updated X6 Firmware and now password won't work
Hi,
I logged into my X6 R8000 and successfully updated the firmware to my iMzc.  Now my password for the router will not work.
Help!
Tom
  • Retired_Member's avatar
    Retired_Member
    Feb 15, 2016
    reset it try default PW
    Retired_Member
  • Maybe the password has been reset back to the factory default?   Have you already tried typing "password" in the password field(or whatever the default password is for your model)?
    • eltoms's avatar
      eltoms
      Yes, i knew that the nuclear option was to reset but was trying to avoid it.  Thanks for your help.
