Graybee's avatar
Graybee
Upgrade Existing Nighthawk R7000 using CFG file
Hello All
I currently use a Nighthawk R7000 router and am looking to upgrade to a more recent version of the nighthawk series but I am unable to find wether or not the newer netgear routers can be loaded with an older router .cfg backup file.
Anyone done this & is it possible?
Alternatively, can the new router "grab" the old router settings somehow?
Many thanks Graham
1 Reply
  • No. The config files are specific & tied to the router model. They are not transferrable due to SDK and hardware/platform differences.
    Take screenshots of your settings and follow them while setting up the new router.
