svr2000
Apr 19, 2026Tutor
Upgrade firmware
I’m trying to update firmware for my 7800 from the admin portal. Even though there’s a newer version available it is saying no new update available. Is that a common issue?
Apr 19, 2026Guru - Experienced User
Yes. R7800 is EoL and so no longer on NGs auto update services.
So if you want new FW, you'll need to manually download it and install it with a PC and web browers.
Also refer to Voxels continued FW as well.
Good Luck.
