NG7856
Jan 19, 2019Guide
Upgrade R7000 for R8000/P or R7800 - firmware stable ( your thoughts and experience)
My AC1900/R7000 is slowly showing its age and needs more reboots (and now a factory reset). I have been told and also saw many articles on the internet that a router's life is 3 -5 years max. with t...
- Jan 19, 2019
My R7000 died (or started to) after 4 or 5 years. Randomly the power LED turned Amber and the router was 'dead'. A reboot brought it back to life but it still happened randomly.
I was looking for a Tri-band as I had some AC devices I wanted to be on its own SSID. I looked at a few vendors. I wasn't too pleased with NG's support as when I first got the R7000 I had DLNA problems with the USB drive. Netgear support always said they couldn't reproduce it and RMA'ed the R7000. I got a REFURBISHED on in exchange at the cost of $15 (USD) postage and insurance. Worse, the problem was there on it as well. ONLY THEN did they work in earnest on the problem. 2 or 3 firmware releases later it was fixed. Other than that the R7000 was basically solid for me. I was never really sure if the R7000 was giving up the ghost or not, but a rollback of the firmware, since that started about 2 weeks after an update, didn't fix it.
In my search I narrowed it down to some vendors, ASUS, LinkSys, Dlink, and some others. Having used ASUS and LinkSys before and had problems they were not really on the top of my list. So I looked at forums for those I could find. Some were not even on vendor owned servers. Looking at the subjects, well, the problems really echoed what one sees here. You never really know the severity of the problem, and even the number of relies isn't a really good indicator. It is user error, user not understanding something, user expecting something else, firmware install errors, hardware issues, router issues???
Next was research... and I mean reviews by websites that don't get paid to do reviews. SMALL NET BUILDER , CNET, TOMS HARDWARE, ZDNET, even AMAZON reviews of the interested routers. Actually I could have picked any of them... and cost was NOT a true factor as all were around $200 to $250 last March when I bought.
I did get the R8000, based mostly on these 2 reviews (https://www.smallnetbuilder.com/wireless/wireless-reviews/32474-netgear-r8000-nighthawk-x6-first-look, https://www.smallnetbuilder.com/wireless/wireless-reviews/32489-netgear-r8000-nighthawk-x6-review-part-2). Deciding factor was that all vendor's have about the same warranty, and some seem more restrictive (could be the legal wording though).
So am I happy with the R8000? Some people are NOT and do have problems, as witnessed here. I'm 'ok' with it. The present firmware has got some problems. Problems that appear to be in common with other routers as well, such as being able to edit the device names on the Access Contol list (I can change them on a mobil device and the changes hold). I recently discovered that my USB drive attached doesn't appear if the router is powered off and then on. I have to disconnect the USB drive either before turning off the router and once up plug it is, or 'chance it getting damaged as it is self-powered' by unplugging it when the router is on and then plugging it back in. Takes some minutes to rebuild the catalog and then it is up.
Another minor problem that might just be the network adapters... never pinned it down, but it seems to occur more often than it did when the R7000 was in place.
Also gave up on Smart Connect. Never worked as Advertised, and the last firmware release now has it handling all 3 bands vs. only the 2 5Ghz bands before. That change seems to have caused many here problems, but it might be part of the Attached Device lists (and the Access Contol list) not being complete or editable.
IrvSp
Jan 19, 2019Master
microchip8
Jan 20, 2019Master
We get regularly threads about R8000(P) problems, both firmware and hardware. I do not recommend this router. The R7800 is far better, both on hardware and firmware (it runs OpenWrt with NETGEAR's GUI on top). It also has one of the best WiFi range out of all NG routers
