ScoWeazy's avatar
ScoWeazy
USB Control Center Freezing on Installation and/or Removal
I'm trying to download the USB Control Center, I'm running Windows 10 Pro N.  Everytime I install, it freezes at the same point.  When I try to repair or install, it also freezes.  I installed it...
  • ScoWeazy's avatar
    ScoWeazy
    Aug 18, 2018
    So apparently I had a bad installation that was causing problems.  I downloaded IObit Uninstaller which completely scraped off the bad install and then tried a fresh install.  Works great now.
