ScoWeazy
Aug 17, 2018Aspirant
USB Control Center Freezing on Installation and/or Removal
I'm trying to download the USB Control Center, I'm running Windows 10 Pro N. Everytime I install, it freezes at the same point. When I try to repair or install, it also freezes. I installed it...
- Aug 18, 2018
So apparently I had a bad installation that was causing problems. I downloaded IObit Uninstaller which completely scraped off the bad install and then tried a fresh install. Works great now.
michaelkenward
Aug 18, 2018Guru - Experienced User
What's that? The ReadySHARE Printer utility?
There is support material, including a manual and any additional software, for the R7000 somewhere at the end of this link:
>>>> R7000 | Product | Support | NETGEAR <<<<
ScoWeazy
Aug 18, 2018Aspirant
Yes, the readyshare printer utility.
- michaelkenwardAug 18, 2018Guru - Experienced User
If the utility is the one on this page, it seems to be out of date and limited to the number or routers supported.
ReadySHARE: Your Router Can Do Everything | NETGEAR
The R7000 is in there.
Is that the software you ran? It installed here in Windows 10 Pro 64 bit.
- ScoWeazyAug 18, 2018Aspirant
