ScoWeazy
Aug 17, 2018Aspirant
USB Control Center Freezing on Installation and/or Removal
I'm trying to download the USB Control Center, I'm running Windows 10 Pro N. Everytime I install, it freezes at the same point. When I try to repair or install, it also freezes. I installed it...
- Aug 18, 2018
So apparently I had a bad installation that was causing problems. I downloaded IObit Uninstaller which completely scraped off the bad install and then tried a fresh install. Works great now.
IrvSp
Aug 18, 2018Master
This doesn't sound like a Router problem? However, if it is a program (unknown what USB Control Center means?) then your PC is the problem. Check the Event Viewer for some hints...
michaelkenward
Aug 18, 2018Guru - Experienced User
That threw me too.
Go look at the Readyshare controls in the browser interface, then ReadyShare Printer:
Step 3: On each computer that will share the printer, download the NETGEAR USB Control Center utility from http://www.netgear.com/readyshare.
Unfortunately, even when you visit the link you are left not much wiser. Heaven only knows which of the various bits there counts as the "Control Center".
