ScoWeazy
Aug 17, 2018Aspirant
USB Control Center Freezing on Installation and/or Removal
I'm trying to download the USB Control Center, I'm running Windows 10 Pro N. Everytime I install, it freezes at the same point. When I try to repair or install, it also freezes. I installed it...
- Aug 18, 2018
So apparently I had a bad installation that was causing problems. I downloaded IObit Uninstaller which completely scraped off the bad install and then tried a fresh install. Works great now.
michaelkenward
Aug 18, 2018Guru - Experienced User
If the utility is the one on this page, it seems to be out of date and limited to the number or routers supported.
ReadySHARE: Your Router Can Do Everything | NETGEAR
The R7000 is in there.
Is that the software you ran? It installed here in Windows 10 Pro 64 bit.
ScoWeazy
Aug 18, 2018Aspirant
