goclmbmnt
Oct 16, 2017Tutor
USB Control Center not working - R7000
USB Control Center just stopped working. It was workng like a champ for quite some time. Now it just stopped. I haven't made any changes on the network. Now, nothing appears on the USB control ce...
- Oct 22, 2017
F-ing ridiculous, spent a s*-load amount of time debugging this issue.
Finally found this thread that worked for me.
I really have not been impressed with the useability of this software. Looking at opensource now...
michaelkenward
Oct 17, 2017Guru - Experienced User
goclmbmnt wrote:
It may have started when i updated the router to the most recent firmware last week...
Did you reset the router to factory settings after the firmware flash?
Some people see this as a knee jerk response, but it is the first thing that support will suggest, and it often works.
New firmware sometimes introduces changes that are not compatible with the old configuration.
So a factory reset is the first thing to try if you have problems with new firmware.
If it isn't too late, first note down the settings – screen grabs can help here.
