goclmbmnt
Oct 16, 2017Tutor
USB Control Center not working - R7000
USB Control Center just stopped working. It was workng like a champ for quite some time. Now it just stopped. I haven't made any changes on the network. Now, nothing appears on the USB control ce...
- Oct 22, 2017
F-ing ridiculous, spent a s*-load amount of time debugging this issue.
Finally found this thread that worked for me.
I really have not been impressed with the useability of this software. Looking at opensource now...
goclmbmnt
Oct 17, 2017Tutor
I guess that makes sense but I would hope that i don’t need to reconfigure the router every time I update it? That seems crazy!!! I’ll try it tonight, unless there’s another, less invasive suggestion someone has?
michaelkenward
Oct 17, 2017Guru - Experienced User
It isn't always necessary, but if you have problems after a firmware flash, you should reset the thing to factory settings, but you can try to preserve your configuration.
My strategy is to:
- save (backup) settings
- flash firmware
If that works and you see no problems, great. If not, and something doesn't work,you may have to reset the device to the default settings:
- set to factory settings
- retrieve settings from backup
If that works and you see no problems, problem fixed! If not:
- set to factory settings.
- reconfigure everything
If that fails, then I fear that you may have to flash back to earlier firmware.
Indeed. Go and place you vote.
Never rebuild a configuration from scratch again! - NETGEAR Communities
