goclmbmnt
Oct 17, 2017Tutor
USB Control Center not working - R7000
USB Control Center just stopped working. It was workng like a champ for quite some time. Now it just stopped. I haven't made any changes on the network. Now, nothing appears on the USB control ce...
- Oct 22, 2017
F-ing ridiculous, spent a s*-load amount of time debugging this issue.
Finally found this thread that worked for me.
I really have not been impressed with the useability of this software. Looking at opensource now...
michaelkenward
Oct 17, 2017Guru - Experienced User
It isn't always necessary, but if you have problems after a firmware flash, you should reset the thing to factory settings, but you can try to preserve your configuration.
My strategy is to:
- save (backup) settings
- flash firmware
If that works and you see no problems, great. If not, and something doesn't work,you may have to reset the device to the default settings:
- set to factory settings
- retrieve settings from backup
If that works and you see no problems, problem fixed! If not:
- set to factory settings.
- reconfigure everything
If that fails, then I fear that you may have to flash back to earlier firmware.
goclmbmnt wrote:
I guess that makes sense but I would hope that i don’t need to reconfigure the router every time I update it? That seems crazy!!!
Indeed. Go and place you vote.
Never rebuild a configuration from scratch again! - NETGEAR Communities
goclmbmnt
Oct 21, 2017Tutor
Thanks for the advice, but it hasn't worked yet. I reset back to factory, reinstalled from my backup and nothing. I then just went back to factory defaults and tried to access the printer, but nothing. So disappointing... Any other advice on how to get the USB control center working again? Each time I went to check if it was working, I just closed and relaunched the control center. Should I have done something else?
- sparkyjoeOct 22, 2017Initiate
I've followed the advice too and am experiencing the same problem. Very annoying.
