OldDuffer
Feb 04, 2017Aspirant
USB drive shows only one partition
Just thrown away my hideous BT Home Hub 3 and replaced it with a Netgear D6400, latest firmware installed (V1.0.0.56_1.0.56). All seems well except for the USB-connected 2TB Western Digital drive I'...
- Feb 07, 2017
Glad to have been usefull to you.
Kudos appriciated.
Have a great day!
OldDuffer
Feb 05, 2017Aspirant
Thanks for your comments and interest, but I'm not sure where this is going: I know it only sees the primary, that's the problem.
The question is whether more recent Netgear kit can or should recognise multiple partitions on a USB drive? My old ADSL router could (I think it was a DGND3300) and the lousy BT kit could ... why not the D6400 which is way superior in all other respects.
Thanks.
Thanks.
- aalexandrebetaFeb 05, 2017Master
Do you have an USB key, make an experiment doing 2 partitons and see if the 2 are recognized or only one?
