OldDuffer
Feb 04, 2017Aspirant
USB drive shows only one partition
Just thrown away my hideous BT Home Hub 3 and replaced it with a Netgear D6400, latest firmware installed (V1.0.0.56_1.0.56). All seems well except for the USB-connected 2TB Western Digital drive I'...
- Feb 07, 2017
Glad to have been usefull to you.
Kudos appriciated.
Have a great day!
OldDuffer
Feb 05, 2017Aspirant
Thanks for your comments and interest, but I'm not sure where this is going: I know it only sees the primary, that's the problem.
The question is whether more recent Netgear kit can or should recognise multiple partitions on a USB drive? My old ADSL router could (I think it was a DGND3300) and the lousy BT kit could ... why not the D6400 which is way superior in all other respects.
Thanks.
Thanks.
aalexandrebeta
Feb 05, 2017Master
Do you have an USB key, make an experiment doing 2 partitons and see if the 2 are recognized or only one?
